I'm getting an error when trying to start the developer edition after following Jianxia Song's instructions of:
'The workaround we have is to get the modules from another place that has the internet installed, then copy the node module folder over to your environment without the internet. Keep in mind, the node version from both places should be the same. Otherwise, you may run into problems. Hope this helps.'
The node version is the same on the workstation where I downloaded the modules and where I am trying to run.
The error is:
\eGIS\Working\Leon\egis_dev\ExperienceBuilder_1.0\server>npm start
> exb-server@0.1.0 start
> cross-env NODE_ENV=production node src/server
internal/modules/cjs/loader.js:800
throw err;
Error: Cannot find module '../../global'
Require stack:
\eGIS\Working\Leon\egis_dev\ExperienceBuilder_1.0\server\node_modules\exb-history-404\index.js
\eGIS\Working\Leon\egis_dev\ExperienceBuilder_1.0\server\src\server.js
←[90m at Module._resolveFilename (internal/modules/cjs/loader.js:797:15)←[39m
at Function.Module._resolveFilename (D:\eGIS\Working\Leon\egis_dev\ExperienceBuilder_1.0\server\node_modules\←[4mexb-ssr←[24m\index.js:1:9904)
←[90m at Function.Module._load (internal/modules/cjs/loader.js:690:27)←[39m
←[90m at Module.require (internal/modules/cjs/loader.js:852:19)←[39m
←[90m at require (internal/modules/cjs/helpers.js:74:18)←[39m
at Object.<anonymous> (D:\eGIS\Working\Leon\egis_dev\ExperienceBuilder_1.0\server\node_modules\←[4mexb-history-404←[24m\index.js:1:2289)
←[90m at Module._compile (internal/modules/cjs/loader.js:959:30)←[39m
←[90m at Object.Module._extensions..js (internal/modules/cjs/loader.js:995:10)←[39m
←[90m at Module.load (internal/modules/cjs/loader.js:815:32)←[39m
←[90m at Function.Module._load (internal/modules/cjs/loader.js:727:14)←[39m {
code: ←[32m'MODULE_NOT_FOUND'←[39m,
requireStack: [
←[32m'D:\\eGIS\\Working\\Leon\\egis_dev\\ExperienceBuilder_1.0\\server\\node_modules\\exb-history-404\\index.js'←[39m,
←[32m'D:\\eGIS\\Working\\Leon\\egis_dev\\ExperienceBuilder_1.0\\server\\src\\server.js'←[39m
npm ERR! code ELIFECYCLE
npm ERR! errno 1
npm ERR! exb-server@0.1.0 start: `cross-env NODE_ENV=production node src/server`
npm ERR! Exit status 1
npm ERR!
npm ERR! Failed at the exb-server@0.1.0 start script.
npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
npm ERR! A complete log of this run can be found in:
npm ERR! C:\Users\vyXXXX\AppData\Roaming\npm-cache\_logs\2020-04-17T01_05_37_572Z-debug.log
The debug log file reports:
0 info it worked if it ends with ok
1 verbose cli [
1 verbose cli 'C:\\Program Files\\nodejs\\node.exe',
1 verbose cli 'C:\\Program Files\\nodejs\\node_modules\\npm\\bin\\npm-cli.js',
1 verbose cli 'start'
1 verbose cli ]
2 info using npm@6.12.1
3 info using node@v12.13.1
4 verbose run-script [ 'prestart', 'start', 'poststart' ]
5 info lifecycle exb-server@0.1.0~prestart: exb-server@0.1.0
6 info lifecycle exb-server@0.1.0~start: exb-server@0.1.0
7 verbose lifecycle exb-server@0.1.0~start: unsafe-perm in lifecycle true
8 verbose lifecycle exb-server@0.1.0~start: PATH: C:\Program Files\nodejs\node_modules\npm\node_modules\npm-lifecycle\node-gyp-bin;D:\eGIS\Working\Leon\egis_dev\ExperienceBuilder_1.0\server\node_modules\.bin;C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem;C:\WINDOWS\System32\WindowsPowerShell\v1.0\;C:\Program Files\Git\cmd;E:\ArcGIS\Pro\bin\Python\envs\arcgispro-py3;C:\Program Files\nodejs\;C:\Users\vyXXXX\AppData\Roaming\npm
9 verbose lifecycle exb-server@0.1.0~start: CWD:
10 silly lifecycle exb-server@0.1.0~start: Args: [ '/d /s /c', 'cross-env NODE_ENV=production node src/server' ]
11 silly lifecycle exb-server@0.1.0~start: Returned: code: 1 signal: null
12 info lifecycle exb-server@0.1.0~start: Failed to exec start script
13 verbose stack Error: exb-server@0.1.0 start: `cross-env NODE_ENV=production node src/server`
13 verbose stack Exit status 1
13 verbose stack at EventEmitter.<anonymous> (C:\Program Files\nodejs\node_modules\npm\node_modules\npm-lifecycle\index.js:332:16)
13 verbose stack at EventEmitter.emit (events.js:210:5)
13 verbose stack at ChildProcess.<anonymous> (C:\Program Files\nodejs\node_modules\npm\node_modules\npm-lifecycle\lib\spawn.js:55:14)
13 verbose stack at ChildProcess.emit (events.js:210:5)
13 verbose stack at maybeClose (internal/child_process.js:1021:16)
13 verbose stack at Process.ChildProcess._handle.onexit (internal/child_process.js:283:5)
14 verbose pkgid exb-server@0.1.0
15 verbose cwd
16 verbose Windows_NT 6.3.9600
17 verbose argv "C:\\Program Files\\nodejs\\node.exe" "C:\\Program Files\\nodejs\\node_modules\\npm\\bin\\npm-cli.js" "start"
18 verbose node v12.13.1
19 verbose npm v6.12.1
20 error code ELIFECYCLE
21 error errno 1
22 error exb-server@0.1.0 start: `cross-env NODE_ENV=production node src/server`
22 error Exit status 1
23 error Failed at the exb-server@0.1.0 start script.
23 error This is probably not a problem with npm. There is likely additional logging output above.
24 verbose exit [ 1, true ]
Any ideas what I'm doing wrong?
Thanks.
