This one!
import arcpy, sys, os from arcpy import env arcpy.env.overwriteOutput = True path_images = "C:/temp/python/raster" rasterList = [] x = 1 for root, dirs, files in os.walk(path_images): for name in files: bands = os.path.join(root,name) if bands.endswith(".TIF") or bands.endswith(".tif"): rasterList.append(bands) if len(rasterList) > 0: out_raster = path_images + "/" + 'raster' + str(x) + ".img" arcpy.CompositeBands_management(rasterList, out_raster) rasterList = [] x += 1
if f.endswith(".TIF"):
if f.endswith(".TIF") or f.endswith(".tif"):
Traceback (most recent call last): File "C:\Python27\ArcGIS10.1\Lib\site-packages\pythonwin\pywin\framework\scriptutils.py", line 323, in RunScript debugger.run(codeObject, __main__.__dict__, start_stepping=0) File "C:\Python27\ArcGIS10.1\Lib\site-packages\pythonwin\pywin\debugger\__init__.py", line 60, in run _GetCurrentDebugger().run(cmd, globals,locals, start_stepping) File "C:\Python27\ArcGIS10.1\Lib\site-packages\pythonwin\pywin\debugger\debugger.py", line 655, in run exec cmd in globals, locals File "C:\Temp\landsatLayerStk.py", line 4, in <module> import arcpy, sys, os File "C:\Program Files (x86)\ArcGIS\Desktop10.1\arcpy\arcpy\management.py", line 12073, in CompositeBands raise e ExecuteError: Failed to execute. Parameters are not valid. ERROR 000735: Input Rasters: Value is required Failed to execute (CompositeBands).
import arcpy, os #arcpy.env.workspace = "C:/Test" arcpy.env.overwriteOutput = True myDir = arcpy.GetParameterAsText(0) bands = [] #?myDownloads = os.listdir(myDir) try: #Walk through directories for root, dirs, files in os.walk(myDir): arcpy.env.workspace = root for f in files: if f.endswith(".TIF"): bands.append(f) #print bands a = ','.join(bands) b = a.replace(",",";") #[f.replace(",", ";") for f in bands] arcpy.CompositeBands_management(b, f[:-7] + ".img") print bands bands=[] print b except: print "Tool did not run" print arcpy.GetMessages()
import arcpy, sys, os from arcpy import env from arcpy.sa import * arcpy.env.overwriteOutput = True path_images = "C:/test" #arcpy.GetParameterAsText(0) rasterList = [] for root, dirs, files in os.walk(path_images): for name in files: bands = os.path.join(root,name) #print bands if bands.endswith(".TIF"): rasterList.append(bands) tilename = name[0:-7] #print tilename + " is being processed." print rasterList out_raster = path_images + "\\" + tilename + ".img" print out_raster #arcpy.CompositeBands_management(rasterList, out_raster) rasterList = [] print rasterList
Hi Josh,Try passing a list of the rasters to the Composite Bands tool. Try the following:import arcpy, sys, os from arcpy import env from arcpy.sa import * arcpy.env.overwriteOutput = True path_images = "J:/Proj/Annual_time_series/Landsat Images/1987/1_001_070/" rasterList = [] for root, dirs, files in os.walk(path_images): for name in files: beni87 = os.path.join(root,name) if beni87.endswith(('B10.TIF', 'B20.TIF', 'B30.TIF', 'B40.TIF', 'B50.TIF', 'B60.TIF', 'B70.TIF')): rasterList.append(beni87) tilename = name[0:-7] print tilename + "being processed." out_raster = path_images + "\\" + "composite.tif" arcpy.CompositeBands_management(rasterList, out_raster)Also, when posting code, be sure to enclose it with CODE tags using the # symbol above.
