Is there a way to format a field in ArcGIS Pro to show currency symbols? (commas and dollar signs)
See image below for attribute table -
You do it from the Fields view
Wow, very easy!
Thank you Dan!
Thanks Dan Patterson ,
I had found this one too, but I cannot get this to translate to ArcGIS Online (AGO).
I had hoped that it would retain this setting when I published the layer up, but it doesn't and get reset to plain integer.
Do you know of a way to get this formatting from AGO?
Thanks either way,
-Matt
