Just looking for a little example code to get started. Need location services. Visual Studio 2017; Xamarin Android project with fragments.
Sorry, I'm just getting rolling with Visual Studio / C# / Android. I couldn't quite work out how the example you sent was getting me to the solution. I came up with this and it works (as good as big-G from my limited experiment):
private Esri.ArcGISRuntime.Location.LocationDataSource _arcDS; private Esri.ArcGISRuntime.Location.Location _arcLoc;
// then in the hosting class ctor:
_arcDS = new Esri.ArcGISRuntime.Location.SystemLocationDataSource();
_arcDS.LocationChanged += ezriHandler;
// later in StartTheFunAsync(): Task t = _arcDS.StartAsync(); await t;
// and finally:
public void ezriHandler(object sender, Esri.ArcGISRuntime.Location.Location esriL) { _arcLoc = esriL; Console.WriteLine("$$$$ Esri Lat:" + _arcLoc.Position.Y); Console.WriteLine("$$$$ Esri Lng:" + _arcLoc.Position.X); }
"Awesome-sauce!" As far as I can tell, it doesn't use any credits.
Hello,
Take a look of the sample link below:
Display device location—ArcGIS Runtime SDK for .NET Samples | ArcGIS for Developers
In addition, MapView.LocationDisplay.Position() gives the MapPoint in lat/lng coordinate
MyMapView.LocationDisplay.Location{Esri.ArcGISRuntime.Location.Location} Course: 0 HorizontalAccuracy: 2990 IsLastKnown: falsePosition: {MapPoint[X=-117.1809, Y=34.0508, Z=0, Wkid=4326]} Timestamp: {10/11/2018 7:48:37 PM +00:00} Velocity: 0 VerticalAccuracy: 0
Hope that helps.
ログインすると、投稿したり、更新をフォローしたりできます。初めてですか?無料アカウントを登録しましょう。
