UpdatesAdded the following new properties, methods, events and constants to existing objects. * Added the ability to query for a feature count to the QueryTask and FeatureLayer classes. These new methods only work for layers published using ArcGIS Server 10 sp1 or greater.
The legend supports the following layer types: ArcGISDynamicMapServiceLayer, ArcGISTiledMapServiceLayer, FeatureLayer. If the layer is an ArcGISDynamicMapServiceLayer or ArcGISTiledMapServiceLayer created using ArcGIS Server 10.01 or higher the legend is generated using the REST Map Service legend resource.http://mapservice-url/legendIf the layers are version 10 or lower the legend is created using the ArcGIS.com legend service. In order to use the ArcGIS.com legend service your map service needs to be publicly accessible and your application must be able to access ArcGIS.com.
Can we get a new local installs for 2.1 under Concepts -> Inside the API -> Frequently Asked Questions -> Can the ArcGIS JavaScript API be installed locally?Thanks!
Kelly, could you elaborate on the Legend Widget a little bit. I have read this: "If the layer is an ArcGISDynamicMapServiceLayer or ArcGISTiledMapServiceLayer created using ArcGIS Server 10.0 SP1 or higher the legend is generated using the REST Map Service legend resource."Once ArcGIS Server 10.0 SP1 is released and you publish your services with that version then the Legend widget will use be generated using the REST map service legend resource. I am not able to use my own ArcGISDynamicMapServiceLayer in the Legend widgets (they are not on ArcGIS.com). Does ArcGIS Server 10.0 SP1 exist yet? Or will the functionality be available only after SP1 is made available? I think more than a few people are scratching their heads over this...Thanks,Ken
ログインすると、投稿したり、更新をフォローしたりできます。初めてですか?無料アカウントを登録しましょう。
