I need help with 10.0 I need to calculate volumes at specific elevations 14.0 to -0.5 within 15 Sq. Miles with 5 defined basins. 9.3 had a nice tab in the 3D analyst pull down that gave us a word document detailing the cut and fill. This is all I need, not a new representation of the surface. I am basing all the calculations on a Tin surface.
I saw that. When I calculate say 1.4 below the surface it creates a file, I do not like the format. The numbers use to have what they represented. Is this something I have turned off or not checked? When I do the next say 1.2 below it wants to over right the file. In 9.3 I just kept modifying the base elevation I wanted calculated and it added it to the document, or is this something I am doing wrong. New to 10.0 I need to get 10.1. Thanks for the help.Bob
