<symbology> <picturemarkersymbol url="/assets/images/i_search.png" height="30" width="30" xoffset="0" yoffset="0" /> </symbology>
<spatialSearchlayer>true</spatialSearchlayer> <removeserchlayersminmaxscale>true</removeserchlayersminmaxscale>
<symbology> <simplefillsymbol color="0x0066CC" alpha="1"> <outline color="0x99FF66" alpha="0.8" width="2" /> </simplefillsymbol> </symbology>
p WHISLER, So it looks like your layer is a polyline, so why are you using symbology for a polygon? If your layer is a polyline then if you change your XML for that layer to use a polyline symbology than you should be fine.
<field name='sqldatabasename."domain\owner_name".tablename.fieldname' alias="Field Name" gridfield="true"/>
