<floatorfixed disablerelatestabinfixed="false">fixed</floatorfixed>
<titlefield>EV Wells</titlefield>
<widgetcontainer layout="fixed">
<widget left="0" right="0" bottom="0" url="widgets/eSearch/SearchWidgetFixedDG.swf" config="widgets/eSearch/SearchWidgetFixedDG.xml"/>
Derek, That is covered in the documentation. It is called hyperlinkaliastext.
<subselection color="0xfbfe0a" linewidth="4" alpha="0.8" />
Jonathan, I do not have anything in place to symbolizing the related features, the symbology that you see is what is returned by the server and then a Glow is added to it when you choose a particular related feature in the datagrid. The glow color is controlled by this line in the eSearchWidget.xml<subselection color="0xfbfe0a" linewidth="4" alpha="0.8" />
Shawn, Are you using the uncompiled source code, or the compiled swfs with the compiled viewer, or app builder?
