Is it possible to use a CartoDB REST endpoint that emits JSON or geoJSON as a layer in my ArcGIS Online map?
It thought there would be something like Add Layer From Web - geoJSON
Thank you -- Tom
Hi Tom,
did you find the way for it.
thanks
pape gowda
you can use esri's koop as an intermediary service for geojson
Esri/koop · GitHub
If you can extend koop to do this job or as an alternative export your data to cartoview and
serve ArcGIS Server REST compatible services from cartoview
You can, in theory, do this by building a CartDB SQL Query which outputs KML, such as https://nps.cartodb.com/api/v2/sql?filename=NPS_Roads&format=kml&q=SELECT+*+FROM+roads%20where%20unit_code%20=%20%27grsm…
and then adding a kml link. Similar to adding a network link to Google Earth
