"To use the sync capability, all the data in the feature service must be from an enterprise geodatabase. Also, you must prepare the data so it can be used offline and, if required, synchronized through the feature service when you have connectivity. How you prepare the data depends on whether the local copy of the data will be editable or read only and, if the local copy of the data will be read only, whether you use versioned data in your feature service.If clients will be editing data while offline and sychronizing their changes when they have connectivity, the feature service must contain nonversioned data."
Exactly the information I was looking for. Thanks!
FAQs—Collector for ArcGIS | ArcGIS - see Q&A Can I use versioned data offline?
Denise
Technical Lead - Apps/Mobile
Is there any further mention of 10.3 supporting offline editing of versioned data? I've searched around but can't see anything about it.
Jack,
With AGS 10.3 release Esri is providing facility to work in offline mode with versioned datasets.
That's cool. Sounds like at 10.3 you will be able to use versioned datasets with an offline workflow anyway
Sorry Shaun... Unfortunately, I never recieved a difinitive response form Esri except that you would have to have a non-versioned DB. I expect that they are expecting you to use the track changes option within the DB. I don't exactly know how that would work, but if you find out, please post. I'm definitely interested.
~~ Good Luck
Did you either get a response to this?
I have a client at the moment that wants to edit data via Collector in offline mode. All their data is in a central database and is versioned. However they won't be able to do this as the data has to be non-versioned to be able to edit offline?
But it can be edited online. Is that right? Is this going to change in the future?
