Yes the Collector update should be rolling out this month
will the disconnected editing be available this release/update?
Nope, it will not
Also waiting on this month's release for line and polygon support.Any plans when disconnected/Sync editing is coming?Thanks.
Just curious, we are having the same issue but our Collector is current. Any ideas?
Thanks
editing on lines and polygons are supported in the Collector today. When you publish your feature service you need to have editing capabilities enabled on the service and those features will be editable in the app.
I believe we have this setup correctly. We can create a new line and update attributes but we cannot change the geometry of a line. We can click to edit the line geometry and change it but after clicking the check (save) we get the following message... "unable to save". We are able to update this layer in other maps too.
Are you using hosted or server? It sounds like an issue with the service. If you are trying the same editing in the web map refresh the web page and see if the edits are saved.
We are using rest services from our server. If I try to edit within a web map on AGOL the save is greyed out but save as is not.
You can try to republish the service, if you have problem editing. Also make sure that "allow geometry updates" is checked when publishing the service.
