You can try to republish the service, if you have problem editing. Also make sure that "allow geometry updates" is checked when publishing the service.
I believe we have this setup correctly. We can create a new line and update attributes but we cannot change the geometry of a line. We can click to edit the line geometry and change it but after clicking the check (save) we get the following message... "unable to save". We are able to update this layer in other maps too.
editing on lines and polygons are supported in the Collector today. When you publish your feature service you need to have editing capabilities enabled on the service and those features will be editable in the app.
Just curious, we are having the same issue but our Collector is current. Any ideas?
Thanks
Also waiting on this month's release for line and polygon support.Any plans when disconnected/Sync editing is coming?Thanks.
Nope, it will not
will the disconnected editing be available this release/update?
Yes the Collector update should be rolling out this month
