.resultsGrid { } .resultsGrid .dgrid-cell { width: 100px; } .resultsGrid .dgrid-scroller { max-height: 200px; overflow: auto; position: relative; }
function populateNorthGrid() { // create query task var queryTaskNorth = new QueryTask(window.northParcelSched); // create query var queryNorthTable = new Query(); queryNorthTable.where = "1=1"; //SQL Query: use the field name like in the attribute table, and then the attibute you want to pull out //queryNorthTable.outFields = ["*"]; queryNorthTable.outFields = ["Date", "Event", 'OBJECTID']; queryNorthTable.spatialReference = new SpatialReference({wkid: 102100 }); // execute the query task // create an object that holds the data from table queryTaskNorth.execute(queryNorthTable, function(results) { var northTableData = array.map(results.features, function(feature) { return { // the fields in order as they are shown on the attribute table "dateField": feature.attributes.Date, "eventField": feature.attributes.Event, "id":feature.attributes.OBJECTID }; // return feature.attributes; }); // create new memory store to hold data // use tableData object to populate it // console.log(northTableData); var northMemoryStore = new Memory({ data: northTableData, idProperty:'OBJECTID' }); var northSchedGrid = new (declare([Grid, Selection]))({ bufferRows: Infinity, // make sure all rows from table show up columns: { //"id": "OBJECTID", "dateField": "Date", // specify the display names "eventField": "Event" }, store: northMemoryStore, class: 'resultsGrid' }, "northSchedGridDIV"); // northSchedGrid.set("store", northMemoryStore); northSchedGrid.startup(); }); }
サインインすると、投稿したり、更新をフォローしたりできます。初めての方ですか?無料アカウントを登録しましょう。
