"[End Site Name]" in "Stops" is on a non-traversable network element position. Invalid locations detected.
routeParams.DirectionsLengthUnits = esriNetworkAttributeUnits.esriNAUMiles;routeParams.FindBestSequence = false;routeParams.IgnoreInvalidLocations = false;routeParams.PreserveFirstStop = true;routeParams.PreserveLastStop = true;routeParams.ReturnCompactDirections = true;routeParams.ReturnDirections = false;routeParams.ReturnMap = false;routeParams.ReturnRouteGeometries = false;routeParams.ReturnStops = false;
1st suggestion:Setting DoNotLocateOnRestrictedElements to True in this case will move the stop to the nearest traversable street. Make sure he also specifies the �??Specified�?� flag:.DoNotLocateOnRestrictedElements = true.DoNotLocateOnRestrictedElementsSpecified = trueThe reason is due to the way how .NET generates proxies for optional SOAP params. 2nd suggestion:If user wants the route to go through this particular street, he will need to turn off the �??Service Roads�?� restriction which by default makes the street non-traversable.On the 2nd page of this OMD http://help.arcgis.com/en/sdk/10.0/Arcobjects_net/pdf/NetworkAnalystObjectModel.pdfThere is RestrictionAttributeNames:IStringArray parameter: ask him to remove �??Service Roads�?� from it before making the Solver request.
NAServerPropertySets serverStopsPropertySets = new NAServerPropertySets(); serverStopsPropertySets.PropertySets = stopPropertySets.ToArray(); routeParams.Stops = serverStopsPropertySets; routeParams.Stops.DoNotLocateOnRestrictedElements = false;
The street where this address is located has been marked as a Restricted Service Road. That�??s the reason why users are not able to route to 4245 Gollihar Road.They can use this attribute doNotLocateOnRestrictedElements and set it to true if they want to bypass the restrictions.
