The Collector app currently does not support searching through map layers right now. This is something we plan on supporting in a future release.Russ
Ditto here. Just confirmed the same in changing the find locations options in the AGOL map. Its great that the intention is there - Like yours, our field personnel are expecting a search by asset #.
The recent update of 10.2.4 Collector supports feature search that have been configured in the web map. You can configure the feature search under the map details.
Cheers
Russ
Rats - I must be missing something on my service or AGOL setup then?. See image of AGOL config below....I've tried both WFS and WMS service options...On searching it either returns no results or the app closes when I hit search. I had installed 10.2.4 on Monday because we need the camera-app fix for Galaxy phones (which works now, awesome). Anything else that I should look to?
thanks
-Nick
Can you share the map and service to a group and invite Collector4ArcGIS into that group and I will take a look and see what the issue is. Let me know what the group is after you share your content.
Thanks
Created a group for you: esristafftestinggroup - Apologies if I sent multiple invites (was in our master account at first).
I have my search set up to look at a layer. I search for a location number of a pole in our system. It still doesn't like it. I started a group where I have shared the map that we are using in the field and have sent you an invite to join the group. The group is called "FEC Answers Group". Any help is appreciated! Thanks!
I will take a look at it and see what the issue is.
Amanda Opp can you update the sharing on the services into that group?
Thanks!
Yes! Sharing all layers and services as we speak. Thanks.
Hey Amanda,
I am able to reproduce the issue you are seeing with your services in the web map as well and it looks like an issue with the JSON that is being written out when the map is saved. Can you please keep the map and services around while the AGOL team looks into the issue. I will send you an update when the issue has been addressed.
Hi Russ!
Thanks for looking at it! I will definitely have the layers on my AGOL until the end of August. Good Luck.
Amanda
Hey there Russ,
I was just wondering what you guys have found? I tried searching again today and still have no search results. Thank you for all your help. I appreciate it.
