System Requirements test say pass but still get unsupported OS while installing.Windows 8.1 64-bitIs this a known issue, any known workaround?[ATTACH=CONFIG]33466[/ATTACH][ATTACH=CONFIG]33467[/ATTACH]
Hi,Today we got heavy problems with drawing - caching.We have an file geodatabase, one polygon layer in it. It´s color is purple. We make an query and get an new polygon layer.Because we created this layer, we can change the colour of this layer. So i change it to orange.BUT! The new colour is shown only in some map scales. When I zoom in or out - the color changes. Sometimes i get polygons which are half orange, half purple - see attachment. You will see the same polygon in several map scales.Deleting the cache doesn´t help. Nor does the auto-refresh in source data options of the layer.And there are better things - we took a newer version of the geodatabase and made the query again - it happens, that not only the colors are wrong, but also the shapes themselves - they are shown from the old database, even if it was deleted and replaced by a newer one.Any solutions?Thank youMichael Glöckner
