I'm not sure if this is a possibility with ArcGIS Online. I would like a map that allows only one layer to be selected at a time. When you select a layer, the other layers would be automatically turned off. Does anyone know how to do this?
like a group layer Add layers—ArcGIS Online Help | ArcGIS
scroll down the help topic,
Thanks. I was hoping to find a way to do this creating a map though, not a scene. That link gives instructions for arranging group layers in a scene. Do you happen to know if it would be possible with a ArcGIS Online map?
Did you have a look through the help? It suggests the same applies
Make your first scene—ArcGIS Online Help | ArcGIS then the group layers section
I've read through it, but I don't see "Create Group at the bottom of the layers in Contents" in the map viewer like it's shown in the scene viewer.
