Error: Error #1502: El tiempo de ejecución del script ha superado el tiempo de espera predeterminado de 15 segundos. at com.esri.ags.components.supportClasses::DoubleField/format() at com.esri.ags.components.supportClasses::DoubleField/set data() at com.esri.ags.components.supportClasses::DoubleField() at com.esri.ags.components::AttributeInspector/createFormItemComponent() at com.esri.ags.components.supportClasses::FormField/getRendererInstance() at com.esri.ags.skins.supportClasses::AttributeInspectorRenderer/commitProperties() at mx.core::UIComponent/validateProperties() at spark.components::Group/validateProperties() at mx.managers::LayoutManager/validateProperties() at mx.managers::LayoutManager/doPhasedInstantiation() at mx.managers::LayoutManager/doPhasedInstantiationCallback()
The problem occurs when you select an item that has fields of type double, probably because the decimal separator in Spanish is the comma (,) instead of the dot (.).
I think this was fixed in the 3.4 release that went public today. Could you download the 3.4 version and try?
