ArcGISDynamicMapServiceLayer agdms = new ArcGISDynamicMapServiceLayer(my_map_server_url); ArcGISLayerInfo[] arcgisLayerInfo = agdms.getAllLayers(); for(int j=0; j<arcgisLayerInfo.length; j++) { arcgisLayerInfo.setVisible(my_boolean_value); }
map.removeLayer(1); layer = new ArcGISDynamicMapServiceLayer(my_map_server_url,Array_with_layers_I_Want); map.addLayer(layer);
Hi, what I do is something like this, depending what you want: ArcGISDynamicMapServiceLayer agdms = new ArcGISDynamicMapServiceLayer(my_map_server_url); ArcGISLayerInfo[] arcgisLayerInfo = agdms.getAllLayers(); for(int j=0; j<arcgisLayerInfo.length; j++) { arcgisLayerInfo.setVisible(my_boolean_value); } Let me know if it helps you.
elecUrl = "http://gis2012.emap.co.il/arcgis/rest/services/CompareElections/MapServer"; elecLayer = new esri.layers.ArcGISDynamicMapServiceLayer(elecUrl, { "id": "elec", "opacity": 0.7 }); if (elecLayer != null) { if (map.layerIds.length > 1) { //var visible = []; //visible.push(-1); //elecLayer.setVisibleLayers(visible); map.removeLayer(elecLayer); } else { elecLayer.setVisibleLayers([0]); var symbol = new esri.symbol.SimpleFillSymbol(); symbol.setColor(new dojo.Color([150, 150, 150, 0.5])); var renderer = new esri.renderer.UniqueValueRenderer(symbol, "WinningParty"); renderer.addValue("א�?ת", new esri.symbol.SimpleFillSymbol().setColor(new dojo.Color([238, 31, 58, 1]))); renderer.addValue("�?", new esri.symbol.SimpleFillSymbol().setColor(new dojo.Color([132, 164, 203, 1]))); renderer.addValue("�?", new esri.symbol.SimpleFillSymbol().setColor(new dojo.Color([121, 71, 0, 1]))); renderer.addValue("�?", new esri.symbol.SimpleFillSymbol().setColor(new dojo.Color([126, 149, 102, 1]))); renderer.addValue("�?", new esri.symbol.SimpleFillSymbol().setColor(new dojo.Color([39, 166, 117, 1]))); renderer.addValue("�?", new esri.symbol.SimpleFillSymbol().setColor(new dojo.Color([71, 102, 36, 1]))); renderer.addValue("�?", new esri.symbol.SimpleFillSymbol().setColor(new dojo.Color([160, 160, 225, 1]))); renderer.addValue("�?�?", new esri.symbol.SimpleFillSymbol().setColor(new dojo.Color([255, 140, 0, 1]))); renderer.addValue("�?", new esri.symbol.SimpleFillSymbol().setColor(new dojo.Color([91, 91, 169, 1]))); renderer.addValue("�?�?�?", new esri.symbol.SimpleFillSymbol().setColor(new dojo.Color([25, 106, 255, 1]))); renderer.addValue("�?רץ", new esri.symbol.SimpleFillSymbol().setColor(new dojo.Color([0, 206, 0, 1]))); renderer.addValue("עם", new esri.symbol.SimpleFillSymbol().setColor(new dojo.Color([182, 212, 168, 1]))); renderer.addValue("שס", new esri.symbol.SimpleFillSymbol().setColor(new dojo.Color([136, 111, 69, 1]))); // set up the parameters for the dynamic layer var optionsArray = []; var drawingOptions = new esri.layers.LayerDrawingOptions(); drawingOptions.renderer = renderer; optionsArray[0] = drawingOptions; elecLayer.setLayerDrawingOptions(optionsArray); // add the layer to the map try { map.addLayer(elecLayer); } catch (err) { console.log(err.message); } }
