How do I access the attachments (photo taken in the field) to download and save on PC? Where are they stored? in the cloud? I can see them when I click on the jpg attachment collected. And get a url when I click but how do I download the photos?
While collecting you can tap the attachment and select rename from the menu.
When I right click on a location, I get this window wants to save picture as a .svg file. The only way I can save the picture is to be in edit mode. Not right click but click on location, then right click on the attachment and Save target as jpg. What’s different from my system?
[cid:image003.png@01D3B783.915A2840]
Siran D. Erysian, M.A., GISP,
Research Analyst II – GIS
Think Spatially
Department of Water Resources
3374 E. Shields Ave, Rm. A-1, Fresno, CA 93726 (559) 230-3312
Siran.Erysian@water.ca.gov
Ok. Its Save target As…..
Is there any way while taking a photo in the field to change the default name? They are all Photo1.jpg
Right click on the link
I don’t’ see where “Save link as” is located. I opened the map in Map Viewer
from pop up
Edit mode in AGOL
If you use the ArcGIS onlline mapviewer on your PC, you could "save the link as..." from the popup to download it.
