okay peeps. Help me, a well-meaning state employee, out. 😃 Why do I keep getting:
from this?! =(
Can you try printing workspace to make sure it's what you want? I think by using os.path.dirname you're backing up to the ArcCatalog folder, but you actually want it to be the .sde, at least according to the example here.
I thought we already solved this problem.
we did. It came back with persistance. =(
edit = arcpy.da.Editor(filepath)
hmmm. Thanks.
You're right. It goes to C:\Users\joanna.grossman\AppData\Roaming\ESRI\Desktop10.4\ArcCatalog.
