dojo.connect(map, 'onLoad', function() { var pt = new esri.geometry.Point(-100, 40, new esri.SpatialReference({ 'wkid': 4326 })); map.graphics.add(new esri.Graphic( esri.geometry.geographicToWebMercator(pt), // geometry new esri.symbol.SimpleMarkerSymbol(), // symbol { 'title': 'Some Title...', 'content': 'Some content...' }, // attributes new esri.InfoTemplate('${title}', '${content}') )); });
<head id="Head1" runat="server"> <title>Untitled Page</title> <script src="http://serverapi.arcgisonline.com/jsapi/arcgis/?v=2.3" type="text/javascript"></script> <link href="http://serverapi.arcgisonline.com/jsapi/arcgis/2.3/js/dojo/dijit/themes/claro/claro.css" rel="stylesheet" type="text/css" /> <script type="text/javascript"> dojo.require("esri.map"); var map; function init() { var initExtent = new esri.geometry.Extent({"xmin":-10427539.398660975,"ymin":5592973.796653195,"xmax":-10358746.073204407,"ymax":5638836.013624239,"spatialReference":{"wkid":102100}}); map = new esri.Map("mapDiv",{extent:initExtent}); var basemapURL= "http://server.arcgisonline.com/ArcGIS/rest/services/World_Street_Map/MapServer" var basemap = new esri.layers.ArcGISTiledMapServiceLayer(basemapURL); map.addLayer(basemap); } dojo.addOnLoad(init); dojo.connect(map, 'onLoad', function() { var pt = new esri.geometry.Point(-118.15, 33.80, new esri.SpatialReference({ 'wkid': 4326 })); map.graphics.add(new esri.Graphic( esri.geometry.geographicToWebMercator(pt), // geometry new esri.symbol.SimpleMarkerSymbol(), // symbol { 'title': 'Test Point Location', 'content': 'This is content' }, // attributes new esri.InfoTemplate('${title}', '${content}') )); }); </script> </head>
function init() { var initExtent = new esri.geometry.Extent({"xmin":-10427539,"ymin":5592973,"xmax":-10358746,"ymax":5638836,"spatialReference":{"wkid":102100}}); map = new esri.Map("mapDiv",{extent:initExtent}); var basemapURL= "http://server.arcgisonline.com/ArcGIS/rest/services/World_Street_Map/MapServer" var basemap = new esri.layers.ArcGISTiledMapServiceLayer(basemapURL); map.addLayer(basemap); dojo.connect(map, 'onLoad', function() { var pt = new esri.geometry.Point(-100, 40, new esri.SpatialReference({ 'wkid': 4326 })); map.graphics.add(new esri.Graphic( esri.geometry.geographicToWebMercator(pt), // geometry new esri.symbol.SimpleMarkerSymbol(), // symbol { 'title': 'Some Title...', 'content': 'Some content...' }, // attributes new esri.InfoTemplate('${title}', '${content}') )); }); }
ログインすると、投稿したり、更新をフォローしたりできます。初めてですか?無料アカウントを登録しましょう。
