Thanks Vinay for quick reply. These graphics are added to the same graphics layer created other than map.graphics.
createFeatureCollection: function (_2f) { var _30 = new this._polygonLayer(); var _31 = new this._polylineLayer(); var _32 = new this._pointLayer(); var _33 = new this._multipointLayer(); if (_2f.declaredClass === "esri.layers.FeatureLayer") { _30.layerDefinition.name = _31.layerDefinition.name = _32.layerDefinition.name = _33.layerDefinition.name = _2f.name || _2f.id; } if (_2f.renderer && !_2.isFunction(_2f.renderer.attributeField)) { _30.layerDefinition.drawingInfo.renderer = _2f.renderer.toJson(); _31.layerDefinition.drawingInfo.renderer = _2f.renderer.toJson(); _32.layerDefinition.drawingInfo.renderer = _2f.renderer.toJson(); _33.layerDefinition.drawingInfo.renderer = _2f.renderer.toJson(); } else { delete _30.layerDefinition.drawingInfo; delete _31.layerDefinition.drawingInfo; delete _32.layerDefinition.drawingInfo; delete _33.layerDefinition.drawingInfo; } if (_2f.fields) { _30.layerDefinition.fields = _2f.fields; _31.layerDefinition.fields = _2f.fields; _32.layerDefinition.fields = _2f.fields; _33.layerDefinition.fields = _2f.fields; } var _34, i; for (i = 0; i < _2f.graphics.length; i++) { var g = _2f.graphics; if (g.visible === false || !g.geometry) { continue; } _34 = g.toJson(); if (_34.symbol && _34.symbol.outline && _34.symbol.outline.color && _34.symbol.outline.color[3]) { _34.symbol.outline.color[3] = 255; } if (_2f.renderer && _2.isFunction(_2f.renderer.attributeField) && !_34.symbol) { _34.symbol = _2f.renderer.getSymbol(g) ? _2f.renderer.getSymbol(g).toJson() : _34.symbol; } switch (g.geometry.type) { case "polygon": _30.featureSet.features.push(_34); break; case "polyline": _31.featureSet.features.push(_34); break; case "point": _32.featureSet.features.push(_34); break; case "multipoint": _33.featureSet.features.push(_34); break; } } var _35 = []; if (_32.featureSet.features.length > 0) { _35.push(_32); } if (_31.featureSet.features.length > 0) { _35.push(_31); } if (_30.featureSet.features.length > 0) { _35.push(_30); } if (_33.featureSet.features.length > 0) { _35.push(_33); } var _36 = { layers: _35 }; var _37 = { id: _2f.id, opacity: _2f.opacity, minScale: _2f.minScale || 0, maxScale: _2f.maxScale || 0, featureCollection: _36 }; return _37; }
