gp = new esri.tasks.Geoprocessor("http://maps.lynxinfo.co.uk:8080/LIVE/services/UKOGL/UKOGLTools/GPServer/Extract Data Task"); gp.setOutSpatialReference({wkid:27700});
function showTResults(results){ dojo.forEach(results, function(result) { var graphic = result.feature; var fMarkerSymbol = new esri.symbol.SimpleMarkerSymbol(esri.symbol.SimpleMarkerSymbol.STYLE_SQUARE, 10, new esri.symbol.SimpleLineSymbol(esri.symbol.SimpleLineSymbol.STYLE_SOLID, new dojo.Color([255, 0, 0]), 1), new dojo.Color([0, 255, 0, 0.25])); var fLineSymbol = new esri.symbol.SimpleLineSymbol(esri.symbol.SimpleLineSymbol.STYLE_DASH, new dojo.Color([255, 0, 0]), 3); var fPolygonSymbol = new esri.symbol.SimpleFillSymbol(esri.symbol.SimpleFillSymbol.STYLE_NONE, new esri.symbol.SimpleLineSymbol(esri.symbol.SimpleLineSymbol.STYLE_DASHDOT, new dojo.Color([255, 0, 0]), 2), new dojo.Color([255, 255, 0, 0.25])); switch (graphic.geometry.type) { case "point": graphic.setSymbol(fMarkerSymbol); break; case "polyline": graphic.setSymbol(fLineSymbol); break; case "polygon": graphic.setSymbol(fPolygonSymbol); break; } map.graphics.add(graphic); }); ext = esri.graphicsExtent(graphic); };
var dlFormat = 'Shapefile - SHP - .shp'; var params2 = { "Layers_to_Clip": clipLayers, "Area_of_Interest": ext, "Feature_Format": dlFormat } esri.show(loading); gp.submitJob(params2, completeCallback, statusCallback, function(error){ alert(error); esri.hide(loading) });
I'm not able to select the layers at Data Extract Widget. Although I've setted the "layers to clip" on the model the "choice list" on rest appear empty.
Is your geoprocessing service published as asynchronous?Does your geoprocessing service expose at least the following three input parameters (with these exact names): Area_of_Interest, LLayers_to_Clip, Feature_Format.
Task: Extract Data Task Display Name: Extract Data Task Category: Help URL: http://lab-arcgis-10/arcgisoutput/beta/ExtractDataTask.htm Execution Type: esriExecutionTypeAsynchronous Parameters: Parameter: Area_of_Interest Data Type: GPFeatureRecordSetLayer Display Name: Area of Interest Direction: esriGPParameterDirectionInput Default Value: Geometry Type: esriGeometryPolygon Spatial Reference: Fields: FID (Type: esriFieldTypeOID, Alias: FID) Shape (Type: esriFieldTypeGeometry, Alias: Shape) Id (Type: esriFieldTypeInteger, Alias: Id) Shape_Length (Type: esriFieldTypeDouble, Alias: Shape_Length) Shape_Area (Type: esriFieldTypeDouble, Alias: Shape_Area) Parameter Type: esriGPParameterTypeRequired Category: Parameter: Feature_Format Data Type: GPString Display Name: Feature Format Direction: esriGPParameterDirectionInput Default Value: File Geodatabase - GDB - .gdb Parameter Type: esriGPParameterTypeRequired Category: Choice List: File Geodatabase - GDB - .gdb Shapefile - SHP - .shp Autodesk AutoCAD - DXF_R2007 - .dxf Autodesk AutoCAD - DWG_R2007 - .dwg Bentley Microstation Design (V8) - DGN_V8 - .dgn Parameter: Output_Zip_File Data Type: GPDataFile Display Name: Output Zip File Direction: esriGPParameterDirectionOutput Parameter Type: esriGPParameterTypeRequired Category: Parameter: Layers_to_Clip Data Type: GPMultiValue:GPString Display Name: Layers to Clip Direction: esriGPParameterDirectionInput Default Value: ComunidadesParameter Type: esriGPParameterTypeRequired Category: Supported Operations: Submit Job Supported Interfaces: REST
ログインすると、投稿したり、更新をフォローしたりできます。初めてですか?無料アカウントを登録しましょう。
