I wish there was a way to turn off all the bells and whistles!!!
I like the idea of background geoprocessing as well, however the implementation does leave a bit to be desired....I think many users would prefer something akin to a cue window... think of the download cue in modern web browsers. You issue a geoprocessing task, and the process is immediately added to a floating window with a progress bar.
There is no usable information in the scrolling bar or the results window. I have had a process running for hours and I have no idea if it is working or not, how far along, etc. I also do not have a way to cancel it without crashing it creating locks, etc. Almost 5 and out nightly updates will start, so I cannot have this processing still. Oh, wait... I found if I right click the tool in the results window I have a cancel option. It would be nice if that was explained in the Help information on the results window.
Followers of this thread may want to know that Esri plans to add 64 bit background processing as an optional additional install for Desktop 10.1 SP 1, which will let you run models and scripts in 64 bit. This could be pretty useful, especially for big geospatial data processes that can crash 32-bit geoprocessing because of memory requirements.
I like this idea.I have to ask though, am I the only person that sees a substantial amount of bottom window margin real estate available for information? Why not use that space down there, instead of just the tiny chunk used now?...
Some positive feedback...Some tools simply can't give you a percent because the process doesn't lend itself to estimates - but this is a nice improvement. Would be nice if more tools provided an estimate even if it's an inaccurate one, just so we know it's working.Followers of this thread may want to know that Esri plans to add 64 bit background processing as an optional additional install for Desktop 10.1 SP 1, which will let you run models and scripts in 64 bit. This could be pretty useful, especially for big geospatial data processes that can crash 32-bit geoprocessing because of memory requirements.
not sure how.but can we cancel the current process of the enabled background geoprocessing?
Yes, you can do that be opening the Results window and right clicking on the running tool. This is also a way to see all the messages as the tool runs.
