Since there appears to be an issue with the GP widget and security, could someone please tell me if my issue is related to this?http://forums.arcgis.com/threads/82625-Flex-Viewer-3.2-GP-Widget-upload-using-10.1.1-returns-token-required
Tim, If you do not have Flash Builder then you will have to wait for esri to release the fix in the next version.
Guys, There is a fix already if you are using the source code of the Viewer.https://github.com/Esri/arcgis-viewer-flex/commit/795cc047677ac3d547d35a963c0ceaed154d0030
