I'm developing maps using ArcGIS SDK and Xamarin.Android.
It all depends what services you are using in your application. Could you describe a bit more which services you are using?
Hello Antti Kajanus,
I’m using the below code to display the current location
MapView _myMapView = new MapView();
Map _myMap = new Map(Basemap.CreateImagerywithLabels());
_myMapView.Map = _myMap;
_ myMapView.LocationDisplay.AutoPanMode = LocationDisplayAutoPanMode.Recenter;
if (!_myMapView.LocationDisplay.IsEnabled)
_ myMapView.LocationDisplay.IsEnabled = true;
If I’m using my personnel network, I can able to view but I’m unable to view with my company network.
When I try to browse arcgis related sites I can able view using my company network.
Please give me the solution.
Regards,
Saritha
You can find the urls from Imagery with labels basemap item.
Seems to be https://services.arcgisonline.com/ArcGIS/rest/services/World_Imagery/MapServer and https://services.arcgisonline.com/ArcGIS/rest/services/Reference/World_Boundaries_and_Places/MapServer
Could you look at the traffic from your application? What sites is it trying to reach, and what errors are you getting? You could use a tool like Fiddler to look at network traffic.
Loop through Source Uri property on the the layers created with the CreateImageryWithLabels() call, and you will see what gets called.
