Another way to make your data available to all SOC machines is to use the operating system tools to share the directory in which the data is stored. Shared directories are commonly referred to with Universal Naming Convention (UNC) paths, which contain the name of the server (for example, \\myServer\data). When you use UNC paths to reference your data, all SOC machines will look to the correct machine for the data.
