Thank you Eric for helping me understand the areal prediction details. To my knowledage, when interpolating a surface from say ordinary kriging, the default is filled contour display; but when further predicting to arbitrary areal unit, you mean the gridded cell values are averaged per area/block? So even when the surface looks continous, the underlying predicted values are still cell-discretized (for a cell size of my choice i understand)?
And a separate question, when the areal units are variable in size, do larger areal units have higher prediction uncertainty (or higher estimated variance), or lower? Thanks again for your insight! I will have to make do with GA for now since i don't have a GGS license...
