FeatureLayer siteLayer = MyMap.Layers["Dispatch"] as FeatureLayer; siteLayer.Where = "Status <> '4'"; siteLayer.Update();
private void FeatureLayer_MouseLeftButtonUp(object sender, GraphicMouseButtonEventArgs args) { FeatureLayer featureLayer = sender as FeatureLayer; args.Graphic.Select(); var l = MyMap.Layers["Dispatch"] as FeatureLayer; args.Graphic.Selected = !args.Graphic.Selected; if (args.Graphic.Selected) MyDataGrid.ScrollIntoView(args.Graphic, null); MyDataGrid.FilterSouce = (from g in l.Graphics where g.Attributes.ContainsKey("status") && (string)g.Attributes["status"] == "completed" select g).ToList(); }
'ESRI.ArcGIS.Client.Toolkit.FeatureDataGrid' does not contain a definition for 'FilterSouce' and no extension method 'FilterSouce' accepting a first argument of type 'ESRI.ArcGIS.Client.Toolkit.FeatureDataGrid' could be found (are you missing a using directive or an assembly reference?)
private void FeatureLayer_MouseLeftButtonUp(object sender, GraphicMouseButtonEventArgs args) { FeatureLayer featureLayer = sender as FeatureLayer; args.Graphic.Select(); args.Graphic.Selected = !args.Graphic.Selected; if (args.Graphic.Selected) MyDataGrid.ScrollIntoView(args.Graphic, null); MyDataGrid. FilterSouce = (from g in l.Graphics where g.Attributes.ContainsKey("status") && (string)g.Attributes["status"] == "completed" select g).ToList(); }
