Hello,
I am trying to use a custom basemap (more updated) rather than the esri one. The problem is that when i use my custom bsaemap I lose the cluster. And even the cluster button disappear in Arcgis online (see attachment).
Any idea about how to solve the issue?
There are some considerations to review when using clusters: https://doc.arcgis.com/en/arcgis-online/create-maps/configure-clustering.htm#ESRI_SECTION1_8D5C42DBE8A24A8B80FC3067DBB19D12
I expect that this is the limitation that you are running into if your basemap is not in WGS84 or Web Mercator
-Kelly
Thank you that solved my problem
