From the looks of it, you're running into the following bug:CQ00312474: Fields for external list values only show on XP machines (not on Win7/Vista)When you are utilizing a dbf table to populate the drop-down lists of a combobox control it requires that you select both the Values and Text fields (Code and Description) from the dbf table.Unfortunately, these lists appear blank on Windows Vista and Windows 7 computers. Until this issue is resolved, you MUST select these values via ArcPad Studio on a computer with a Windows XP operating system.
Hello,I am having the same problem but your solution has not worked. I'm trying to link to a DBF table to populate a combobox drop down. I can link to the table but there are no visible options in the value and text fields. I have all the files on my local computer and I'm using Windows 7. Please help.Olivia
