Hi Dana,Are you referring to NIM071576: The Feature to Point tool creates a different center point when the option to constrain the point to the inside of the polygon is enabled, but the center point is actually inside the polygon. ?If so, it shows as having been fixed in the next release.Best,Melanie S.
Dana, if possible, please share a sample data so I can double check for you. Thanks.
