なぜサービスは時間対応されていないように見えるのでしょうか?タイムスライダーに基づいて異なる画像を簡単に視覚化する方法はありますか?<\/P>
<\/P>
「acquisition date fileld」でフィルターを追加することが可能であることは知っていますが、この機能は実際には最終ユーザーにとってあまりパフォーマンスが良くなく、直感的でもありません。<\/P>
どうもありがとうございます。<\/P>
Enrico<\/P><\/BODY><\/HTML>
Megan,To achive this, you have to enable "Individual Image Search", specify the Sentinel-Layer and the AquisitionDate Field. I have created and attached a short video that might be easier to follow than a lengthy text. Plus the dummy app shown in the video will be available for a few days. The control with the 3 vertical bars opens the UI to select a specific date available in the extent chosen.Hope this helps!G.
Enrico,
the ImageService has all information to use time - as you clearly state - but it prevents users to enable time slider functionality by not having "use time" activated in the Service properties to avoid "un-aware" use that might result in senseless processing and searches blocking other users from proper access. The new Imagery Apps now work with another method and selector. Try to use for example the new:
There you can easily configure the layer to give you a dropdown of available dates for a selected area ... RegardsGuenter
Thank you Guenter,
Why this solution respect Landast image services that are time enabled ?
Imagery viewer is nice but we would integrate natively this kind of services in AGOL and in Web Appbuilder
together with other time enabled layers (i. e fires, air quality etc).
Thanl you for your collaboration
regards
Enrico
Valid question,
Have no details there. And no complete answer. Data structures are completely different in the stores we can access – maybe someone else will comment here
You have a good point. There are advantages and disadvantages of making the layers time aware. The issue has been that when time aware some app default to the earliest time and this does not work well for such services. Also the standard time line tools are not very effective at working with images with such disparate times. Hence the suggestion to use the time selector tools. Note there is now a image/time selector in the WebMap Viewer as well as in Pro and using Web Apps (see WABIS) and the new Imagery Configuration templates. The Sentinel service is currently Beta status we will look to possibly change the setting to time enabled (but keep default as off) for the release which should happen relatively soon. I'll add your name to the 'enable time' vote.
Thank you Peter, I see your point: it's not an easy issue..
Please could You give me some more news about the "image/time selector in the WebMap Viewer "?
I tried to looking for in AGOL and in WABI but I didn't find nothing similar?
Thank you very much for Yourhelp!
Image Filter is part of Web Map Viewer in ArcGIS Online. Was added a few months ago, but latest version work better with Sentinel 2.
Add Sentinel-2 Views
Click on Filter
Press on 'Remove Filter' - This removes a filter that limits the display only to latest dates.
Click on 3 dots and select Image Filter
Now you can set filters to any range you want, see key attributes of the image and add the layers to your map
Hello, It would be great if time slider widget can pick up time from Sentinel 2 imagery (Living Atlas of the World) in Web App builder or in the Experience builder. Any update or alternative solution is appreciated. Thanks
@GuenterDoerffel I am working with the imagery viewer apps, but am not seeing the option to find images by date. See screen shot and configurations below. Is there a way to enable this in the updated viewer? Thank you!
Morning all,
The Sentinel 2 imagery Living Atlas of the World is now 'time aware' in ArcGIS Online and Web App builder but not in Experience Builder. Able to use the Slider instant app to create a manual time lapse for my team.
Thanks
Perfect! I totally missed that radio button!
