私はWindows 10 (1803) x64上で、以下のハードウェアを使用して最新ビルドのDrone2Map (v1.3.1) を使用しています:<\/SPAN><\/P><\/SPAN><\/P>- Dell Precision 5820<\/SPAN><\/SPAN><\/P>- Intel Xeon W-2104 3.2GHz, 4C, 8.25M Cache<\/A><\/SPAN><\/SPAN><\/P>- 32 GB RAM<\/SPAN><\/SPAN><\/P>- 1024 GB SSD<\/SPAN><\/SPAN><\/P>- NVIDIA4 Quadro4 P4000, 8GB, 4 DP<\/SPAN><\/SPAN><\/P><\/SPAN><\/P>「Use CUDA」オプションを確認し、「CPU Threads」を最大に設定しました。約210枚の画像を使って2D mappingテンプレートでデモプロジェクトをレンダリングしようとしています。<\/SPAN><\/SPAN><\/P><\/SPAN><\/P>ログファイルにはグラフィックカードが認識されCUDAが有効になっていると表示されていますが、GPUモニターで確認するとGPUは全く利用されていません。最新のNVIDEA Quadroドライバーをインストール済みです。<\/SPAN><\/SPAN><\/P><\/P>処理にGPUを関与させるために追加の手順は必要でしょうか?<\/SPAN><\/P><\/P>よろしくお願いいたします。<\/SPAN><\/P><\/P>Christian<\/SPAN><\/P><\/BODY><\/HTML>
This is the recommendations for the Spatial Analyst extension. I would assume it would be the same for the rest of the suite. Is it where you got your information?
GPU processing with Spatial Analyst—Help | ArcGIS Desktop
Hi Dan,
the only information I found on the Drone2Map CUDA option where from here: Processing options—Drone2Map for ArcGIS Help | ArcGIS
And I found an older thread, but it did not help me to get my GPU involved in the processing: https://community.esri.com/thread/192142-drone2map-killing-my-computer
Regards,
Christian
Using the Nvidia control panel, select 3D Settings > Manage 3D Settings > Global Settings > Global Presets > "3D App-Game Development > Apply
Thank you - that fixed it!
Glad to help!
Facing the same issue but not seeing any of these options when opening the NVIDIA Control Panel.
Hardware Specs:
NVIDIA:
Here is the NVIDIA Control Panel:
Not sure what you are seeing on your side... I access the control panel from simply right-clicking on the desktop and this is what I see. Granted this is installed locally on my workstation, not running through a network or server which could be your issue.
Hi Patrick,
Is there any reason why Global Presets tab doesn't show up in Nvidia control panel?
Hello,
I see you are on Windows Server Datacenter. Physical or virtual machine? Is your account a server administrator? Looks like you are able to view NVIDIA Control Panel as a lower privileged user and not a server administrator. Server administrator privileged user will see the options you cannot.
ログインすると、投稿したり、更新をフォローしたりできます。初めてですか?無料アカウントを登録しましょう。
