A problem occurred while parsing and charting the returned elevation data: Error #1010: A term is undefined and has no properties.
trace(event.result.toString());
Hi Rhett,
We are trying to find a flex widget for Elevation profiles configured to work with the 10.1 AGS Elevation Profile SOE. I see where you have supplied a 10.0x version of the widget and where you were looking at the 10.1 SOE. Did you ever produce a working widget with 10.1 (REST) and if so would you mind sharing? Thanks.
Vince,
I no longer have access to that and no ability to develop/test at this time.
However, I believe the first ElevationProfile.zip file that Robert provided above will work with 10.1, and the chartwindow.xml provided later makes it work with 10.0. So, give his first attachment a try.
R_
