huge challenge the Migration of the content on ArcGIS Online to Portal - any suggestions? any tools that we can use to make is easier and not just one by one item? Thank you! Jack
Links to check:
Can We Move The Files From ArcGIS Online To ArcGIS Portal?
Example: Copy content—Portal for ArcGIS (10.6) | ArcGIS Enterprise
This script can also be used to move content from Portal for ArcGIS to ArcGIS Online and vice versa.
Thank you much, definitely will try - is it possible to move all type of content? is it limitted on how many files or groups can be transferred? Thanks again!
