Hi , I am using Flex 2.1 and Alive pdf to export map object to pdf. I am able to export the Map object to pdf .Before exporting , I have removed the scalebar , zoomSliderbar and logo from com.esri.ags.Map object.but the updated map object is not reflected in the pdf.private function exportToPdf():void{ portPDF=new PDF(Orientation.LANDSCAPE,Unit.MM,Size.LETTER);portPDF.setDisplayMode(Display.FULL_PAGE,Layout.SINGLE_PAGE);portPDF.setMargins(2,2,2,2);portPDF.addPage();var rs:org.alivepdf.layout.Resize=new org.alivepdf.layout.Resize("FitToPage","left");myMap.scaleBarVisible=false;myMap.zoomSliderVisible=false;myMap.logoVisible=falseportPDF.addImage(myMap,rs,3,3,420,300,0,1,false,ImageFormat.JPG,100,"Normal",null);const fileReference:FileReference = new FileReference();fileReference.save(portPDF.save(Method.LOCAL,"",Download.INLINE,"portPDF.pdf"),"map.pdf"); myMap.scaleBarVisible=true;myMap.zoomSliderVisible=true;myMap.logoVisible=true; } I am not sure , if i am missing something. Thanks in anticipation of your help.Regards, Nidhi
