I have a need to view my maps in the Flex Viewer (or are we calling it Flash Viewer now?) in UTM 11N. I need the data from the MGRS to be correct and that is projected to UTM. Printed maps will be used to navigate using the MGRS. However, the basemap (ESRI StreetMap, etc) is the WGS 84 projection. How would this best / most easily be handled?Thanks in advance...Brad
<esri:Map id="map" units="{Units.FEET}"> <esri:extent> <esri:Extent xmin="661140" ymin="-1420246" xmax="3015668" ymax="1594451"> <esri:SpatialReference wkid="26777"/> <!-- NAD_1927_StatePlane_Kansas_North_FIPS_1501 --> </esri:Extent> </esri:extent> <esri:ArcGISDynamicMapServiceLayer url="http://sampleserver1.arcgisonline.com/ArcGIS/rest/services/Demographics/ESRI_Census_USA/MapServer"/> <esri:ArcGISDynamicMapServiceLayer url="http://sampleserver1.arcgisonline.com/ArcGIS/rest/services/Petroleum/KGS_OilGasFields_Kansas/MapServer"/> </esri:Map>
