How authorize ArcGIS Pro 1.3 personal use, the site My ESRI under no such authorization functions (although ArcGIS Desktop 10.4 is such an opportunity, and it works fine). How can I authorize ArcGIS pro through ArcGIS Online?
You need to login to your ArcGIS Online named user account.
Then, configure the ArcGIS Pro license to your named user.
Follow the steps in Manage Licenses - ArcGIS Online
Many thanks for the answer. But I can not find a tab or link to license or right to access ArcGis Pro at My ESRi, although the license file to the ArcGIS desktop 10.2 - 10.5 and I formed using such operation for ArcGIS Pro I can not do. How to solve this problem?
You won't get it in My Esri. Login to http://www.arcgis.com. Then proceed with the instructions.
Grateful for your advice. Now I understand, but the problem is that the tab is missing after authorization. What to do in this case? When purchasing a license, I did not get a link to additional registration for ArcGIS Online. You may need to contact somewhere in obtaining such rights?
I'd recommend calling Esri Support Services to get this resolved - their phone number is 1-888-377-4575http://support.esri.com/contact-tech-support
So I turned to the regional office of the support (I live in Ukraine). They reported that they can not solve this issue because there is no access to my account. The reason is that I bought a license directly on the site. In representation advised to refer to the main support center. I am here just do not understand where to write.
Could you explain how you bought the licence from the site? Thanks.
On website http://www.esri.com/software/arcgis/arcgis-for-personal-use fulfilling every item made a deal to purchase presonal license and paid for it. Got in my mail confirmation of payment. After received a letter referring to my.esri for further activation, where he received the activation file ArcGIS Desktop 10.1-10.5, which is activated and works well. More I received no links or activation. Therefore, after the installation and attempts to activate ArcGIS PRO response I got. "Public Account user cannot access this application ArcGIS Pro" So I had to ask for help. As a result, have found that I can not access My Organization at http://www.arcgis.com/home/index.html, so I can not access to ArcGIS Pro.
I have this issue too
Did you already go through How to Manage Your ArcGIS Pro License with ArcGIS Online ?
Yes, We have 6 concurrent standard licenses. It shows only 3 pro on authorizations. i know 3 have been set up for our license manger. i was thinking i should see 3 on AGOL yet but there are not any shown. I don't even see a chart that says pro authorization in AGOL.
Hillary, I think that the next best step would be to contact Customer Service to sort out which customer account your subscription is associated with, and check to make sure the number of licenses is correct and that those are active. I would do that (Customer Service) before technical support.
I couldn't figure this out via a LOT of clicking around my.esri.com. I eventually went back through my email from when I signed up. I found a link to my "Fulfillment Page" that got me what I needed. That fulfillment page is also at my.esri.com, but it opens with a special code in the URL. Once I found that, there were still quite a few steps, but the instructions were pretty clear.
The overview of the process from the fulfillment page is to:
THANK YOU! That actually worked. Why the personal use lic. instructions don't say this is beyond me because it would have saved me a world of frustration.
I have a question regarding those steps in the fulfillment page... What if we don't want to create a new organization?
We have an AGOL organization and I would like to assign this home pro license to a member whithin our AGOL organization. would be that possible?
If I create a new AGOL organization, I understand that I wont be able to access to the content in the previous AGOL organization when I sign in using this new user credential inside the "new" AGOL organization. Does that make sense?
