Easy done in arc desktop. Use Tabulate Intersection (Analysis Tool Box > Statistics). This will create a table of the sum of the line within the polygon feature. The table will hold the polygon id. Join this table back to the original polgyon layer
CLASSIFICATION: UNCLASSIFIED
Do you know Python? I so you can use the Python API and write a script to filter your table on road lengths and road types and then use the Pandas and Seaborn libraries to make a histogram. I have also seen a new little set of libraries called plot.ly but I haven't used them yet. If you don't know Phython, I would suggest exporting your table to a CSV file and importing it into Excel and use Excel's plotting tools to make your histogram.
I hope this helps
Does anyone know how to do this without Summarize Within tool? My ArcMap 10.6.1 does not have this tool. I would like to summarize road lengths by road type within a county.
Thanks in advance!
Summarize Within—Help | ArcGIS Desktop
might be in arcmap, but it is in pro for sure
I have some polygons with some polylines in it (same as above). The polylines divided into three categories (for example: urban street, highways, freeways) I want to understand the sum of each polyline in each of the polygons.
I mean for example I want to know the total length of the urban streets in Polygon A.
I find a boring way for this,First spiliting the roads for each polygone then selecting by attribute, clicking on the attribute table and in the statistics I can see the sum of the selected features. But I am looking for a faster way. I also tried the Spatial Join but this option only gave me the total length of the all types of road in each polygon. I want the total length of each polyline seperately. Something just like this:
sum of urban roads in polygone A: 17526 m
sum of highways in polygone A: 18945 m
sume of freeways in polygone B: 8900 m
etc
Does anyone know the fastest way to find these numbers?
