>> toolbar._options { showTooltips : false, drawTime : 75, tolerance : 8, tooltipOffset : 15 }
toolbar = new Draw(map, { showTooltips: true });
Was this issue addressed?I'm seeing the same problem in IE10.It seems like the "showTooltips" option never gets set.i.e. in the developer tools console it looks like this:>> toolbar._options { showTooltips : false, drawTime : 75, tolerance : 8, tooltipOffset : 15 } Even if I explicit set it (even though the documentation says it's on by default). toolbar = new Draw(map, { showTooltips: true }); I can also confirm that if I inspect the esri.bundle.toolbars.draw object it has values for all the properties ("start" = "click to start drawing", "complete" = "Double-click to complete", etc).It displays correctly in chrome and IE8.
ログインすると、投稿したり、更新をフォローしたりできます。初めてですか?無料アカウントを登録しましょう。
