デザイナーで作業しているときは、マップを調査に添付するのに問題はありません。しかし、公開するとマップは白く表示され、ホバーすると「Loading」と表示されます。これが長時間続きます。この機能を動作させるために確認すべき設定はありますか?この機能は Survey123 モバイルアプリケーションでは動作しますが、デスクトップブラウザでは動作しません。<\/P><\/BODY><\/HTML>
Hi Tyler,
Can you provide a few details about how your Survey is set up?
1) What is the background web map? Is it shared publicly, or just within your organization?
2) Given the designer view, it appears that you are asking for the user's location. In the browser of the published view, have you been prompted to share location access? If so, have you granted or denied?
Hey James,
Thanks for the reply and taking the time to try and figure this out.
Currently my settings are as follows: The background map is the default streets basemap that it starts out with, however, it doesn't matter which one is on there because the end result is the same. I designed the survey using a web browser and not Survey123 Connect. I have tried asking and not asking for a users location so that doesn't seem to matter. Do you think it might be something within the browser not enabled that could be causing this issue? The field applications on the phone and the desktop work fine. This only happens in the browser.
Thanks again
Can I ask you to open the Developer tools of your browser and watch the network traffic as you reload the form? It sounds like something isn't getting loaded successfully.
