Jayateerth,
Sorry you didn't get a response sooner, I too have a need for this and in my testing, I was able to replace HTTP with HTTPS and port 6180 with port 6143 and everything worked successfully. I was told at 10.7 GeoEvent will by default display the HTTPS pattern. As long as you have a security cert from a certificate provider and you have HTTPS enabled you will be able to do this. If not then I suggest you read up on the tutorials provided with GeoEvent Server and then you can make the change to your Reciever.
Hi All,
I am trying to design a Input Reciever in GEP using 'Receive Features on a REST endpoint'.
When Created, the GEP gives me a rest endpoint in HTTP protocol.
e.g. http://<hostname>:6180/geoevent/rest/receiver/<input name>/
Can any one help me create this url in HTTPS mode, as we have set up ArcGIS Server/Portal etc in HTTPS mode.
[ { "CITY_NAME": "Brasilia", "POP": 2207718, "POP_RANK": 2, "POP_CLASS": "1,000,000 to 4,999,999", "LABEL_FLAG": 0, "shape": { "x": -47.897705078125, "y": -15.7921142578125, "z": 0, "spatialReference": { "wkid": 4326 } } }, { "CITY_NAME": "Goiania", "POP": 1171195, "POP_RANK": 2, "POP_CLASS": "1,000,000 to 4,999,999", "LABEL_FLAG": 0, "shape": { "x": -49.2550048828125, "y": -16.72698974609375, "z": 0, "spatialReference": { "wkid": 4326 } } }, { "CITY_NAME": "Cuiaba", "POP": 521934, "POP_RANK": 3, "POP_CLASS": "500,000 to 999,999", "LABEL_FLAG": 0, "shape": { "x": -56.093017578125, "y": -15.614990234375, "z": 0, "spatialReference": { "wkid": 4326 } } }, { "CITY_NAME": "Campo Grande", "POP": 729151, "POP_RANK": 3, "POP_CLASS": "500,000 to 999,999", "LABEL_FLAG": 0, "shape": { "x": -54.61590576171875, "y": -20.45098876953125, "z": 0, "spatialReference": { "wkid": 4326 } } }, { "CITY_NAME": "Salto del Guaira", "POP": 7385, "POP_RANK": 7, "POP_CLASS": "Less than 50,000", "LABEL_FLAG": 0, "shape": { "x": -54.2833251953125, "y": -24.04998779296875, "z": 0, "spatialReference": { "wkid": 4326 } } }, { "CITY_NAME": "Encarnacion", "POP": 74983, "POP_RANK": 6, "POP_CLASS": "50,000 to 99,999", "LABEL_FLAG": 0, "shape": { "x": -55.85101318359375, "y": -27.37701416015625, "z": 0, "spatialReference": { "wkid": 4326 } } }, { "CITY_NAME": "Posadas", "POP": 312060, "POP_RANK": 4, "POP_CLASS": "250,000 to 499,999", "LABEL_FLAG": 0, "shape": { "x": -55.906005859375, "y": -27.39801025390625, "z": 0, "spatialReference": { "wkid": 4326 } } }, { "CITY_NAME": "Puerto Maldonado", "POP": 37543, "POP_RANK": 7, "POP_CLASS": "Less than 50,000", "LABEL_FLAG": 0, "shape": { "x": -69.1920166015625, "y": -12.60302734375, "z": 0, "spatialReference": { "wkid": 4326 } } } ]
