Yeah I've noticed similar behaviour with ArcGIS caching. If you click on the Job Status tab, what does the job code say? Can you right click and go Fix Errors? Sometimes that will finish the cache off or you could go Manage Tiles and then just create for empty tiles only. Have a look at memory resources too and make sure there is enough memory on the server to create the cache.
What if you go Complete Job, will it continue caching? Also that area of interest feature class you've got there - "Governorate_WestBank". How much of the area is that covering? I notice when you do that, it doesn't update cache status percentage i.e. The percentage of completion is done for the full area, not just the area of interest, so it may have fully completed, even though it says 50% or whatever. Did you have a look at the map service to see what areas are/are not cached?Hopefully that helps a bit 🙂
