conner_justin,for some documentation concerning the "toRemoveLayoutElement", you should check this page:http://bitbucket.schuller.lu/pchprintsoe/issue/16/print-mxd-template-layoutTom
<toRemoveLayoutElements></toRemoveLayoutElements>
java -classpath "C:\Program Files (x86)\ArcGIS\Server10.0\java\lib\arcobjects.jar;C:\Program Files (x86)\ArcGIS\Server10.0\java\tools\soemanager\SOEManager.jar" com.esri.arcgis.tools.SOEManager -a 172.26.197.91 localhost administrator aVp105 PCHarcgisSOE.jar
Hy,Seems to be related with the JSON support now new in 4.6! I didn't yet installed FlexSDK4.6To get a quick fix, just install the FlexSDK4.5 and compile with 4.5I will download the SDK4.6 and will update the code.Tom
params["mapExtent"]=com.esri.ags.utils.JSON.encode(mapExtent);
Could you restart your ArcGIS-Server services (not the mapservices).Is your "ortho2009" printSOE enabled? You just have to make the "layout" mapservice PrintSOE enabled.If it's enabled on the "ortho2009" mapservice, disable it.Tom
<Debug enabled="true"/>
Matt,your arcgis server isn't getting any request from the widhet.Could you check if the "printurl" is correctly configure in the PChprintWidget.xml?Maybe it's using an older version from your browser cache.Tom
サインインすると、投稿したり、更新をフォローしたりできます。初めての方ですか?無料アカウントを登録しましょう。
