great,could we just check why you got the wrong download files?Could you post you download link and maybe how you got it?Tom
Eric,let me know about here labels and the things you disabled.I will add it to be configurable in the xml file.Tom
Eric,would this be ok as title background? See attachmentI just updated the BitBucket sourcecode and binaries for the SOE and the widget:http://bitbucket.schuller.lu/pchprintwidget/changeset/7db4aa887f14/http://bitbucket.schuller.lu/pchprintsoe/changeset/069e396f5e75/Tom
Tom,Yes, that is it...I'm assuming there is a choice (or I could configure) the background color?I tried implementing it on my end to no avail - yet.I will try the code you posted.Thanks muchEric V
I havent even gotten this far, but where are *create an empty mxd and publish it as a "layout" mapserviceand *enable the PrintSOE and the printMap operation on itcompleted?
Evan,could you ping the "MWELLAGSSERVER"?If not could you ping the ip-address?Mostly the problem is coming from the firewall.You could get more infos of this problem in my BitBucket:http://bitbucket.schuller.lu/pchprintsoe/issue/3/error-trying-execute-soemanagerbatTom
Evan,yes, it seems that the firewall has blocked some access needed by the "soemanager".You just have to disable temporary the firwall during the registration of the SOE by the "soemanager". After registration, you can switch again on the firewall.Tom
The Flex 4.6 SDK includes JSON support, if you are including your own JSON classes either directly or through a shared library you�??ll have to remove them in order to use the new SDK.
I'm pretty sure the firewall is turned off completely, but I'll give it a shot when I'm back in the office on Friday. Thanks for the help.Evan
C:\Program Files (x86)\ArcGIS\Server10.0\java\tools\soemanager>soemanager.bat -a 172.26.197.91 mwellagsserver administrator aVp105 PCHarcgisSOE.jar C:\Program Files (x86)\ArcGIS\Server10.0\java\tools\soemanager>java -classpath "C:\Program Files (x86)\ArcGIS\Server10.0\java\lib\arcobjects.jar;C:\Pr ogram Files (x86)\ArcGIS\Server10.0\java\tools\soemanager\SOEManager.jar" com.esri.arcgis.tools.SOEManager -a 172.26.197.91 17.26.197.91 administrator aVp105 PCHarcgisSOE.jar Error: AutomationException occured while connecting to server 172.26.197.91. Please check if username and pwd are correct or are members of agsadmin group. AutomationException: Access is denied. Disconnecting from ArcGIS Server "null"...Done. C:\Program Files (x86)\ArcGIS\Server10.0\java\tools\soemanager>java -version java version "1.6.0_16" Java(TM) SE Runtime Environment (build 1.6.0_16-b01) Java HotSpot(TM) Client VM (build 14.2-b01, mixed mode)
