I have 1 single layer with a comment table in a feature service working in the Crowdsource Reporter and when I open up in Manager all the reports are there, but when I go to create multiple comments within manager they won't appear. When I open the feature service up in arcgis.com map viewer and show related records they are all there. Any idea how i may be able to get them all to show up in manager.
It is now possible to display popups for the uneditable layers. There is an option to enable this in the application configuration. Note that the option to display reference layers must also be checked in order for the reference layer popups to display.
pemcbride: Can you share the URL to your application? You are correct that Manager should show the related records. I haven't seen this before and it will be easier for me to troubleshoot if I can see what's goign on myself.
-Allison
Allison,
Thank you for the response! I'm sorry I wasn't aware that you posted. I was able to get it to work. I completely rebuilt my database and how the related tables work.
Do you know how to enable pop ups within the application for features other than the editable features?
Thank you!
Paul
I think I'm having a similar issue, do you remember what you may have changed this time around to get the relationship to show?
pemcbride Showing popups for the uneditable layers is on our backlog, but not currently possible. You can label the uneditable layers, though.
