Hi.
Is it possible to add a feature to AGOL so when the user saves a map, AGOL will create a backup copy with the timestamp when it was last changed, so the user can then revert back if necessary.
Thanks.
Check out this idea:
https://community.esri.com/ideas/11729
Are you worried about reverting back because of unwanted edits to features or is it unwanted changes to the map configurations like symbology, pop ups, etc?
Hi
I am only worried about making changes to the Map Configuration only.
