... This results in ~5,000 catchments. GIS seizes up once I get to the drainage line processing tool. ...
I get so many concerns about drain issues & while there are typical drain issues, there is not a normal, easy respond to any drain issue you may be having. If you have a bit of hair in the trap, yes it will fresh that but a plunger will do the same. Please save your income & don't buy any junk.
